Date/Time: Wed, 25 Nov 2026 21:06:01 +0000
TPO Stock charts
View Count: 480
[2025-06-21 14:48:30]
User871035 - Posts: 2
Hi team, I'm currently trying to figure out how to use TPO on Stock charts and whenever I load up NVDA, it just shows TPOs from 9:30am to 9:31am. I've tried to redownload the data and it didn't work. I've tried to change the sessions start and end times, this didn't work either.
I am using NVDA-NQTV feed. Are there any suggestions so I can display the TPOs correctly, or any settings I need to be aware of that I must change? I want to view the FULl day trading data for NVDA. Not just US session. I have gone through the board for previous suggestions and those that I have tried have not assisted with this issue. The chartbook works perfectly fine on ES, but it doesn't for stocks and I've tried changing the tick size etc it doesn't work.
Please let me know your thoughts.
[2025-06-21 15:40:27]
First thing to do is this:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
And check the Session Times:
Chart Session Times
Make sure they are set correctly.
Date Time Of Last Edit: 2025-06-21 15:41:06
