Date/Time: Wed, 25 Nov 2026 20:51:55 +0000
Missing Daily Historical Data?
View Count: 620
| [2025-06-20 21:26:50] |
| AlexH4 - Posts: 28 |
missing some daily historical data with some ticker! 1) Data/Trade Services Setting -Max Historical Days To Download is set to 9000 2) Chart Settings -Days To Load Historical Chart Data also set to 9000 really annoying need help to figure out why is doing that thank!!! |
| [2025-06-23 14:55:06] |
| John - SC Support - Posts: 48658 |
What data is missing?
| [2025-06-23 15:14:54] |
just trying to figure out.. there is more days then that you see on the chart and with the setting i have should load more days.... |
| [2025-06-23 16:06:50] |
Are you using a Continuous Futures Contract option? Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-23 16:38:51] |
No am not using this should i? And I just see that it will not have any effect with stock.. Just for reference in the picture the stock i watch is symbol: AIFF |
| [2025-06-23 19:06:53] |
You do not need to use a Continuous Contract with stocks. That is only for futures. To get more data for stocks into a chart, follow these instructions: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using 'Date Range in File >> From' to Download More Historical Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
