Date/Time: Sat, 04 May 2024 08:43:08 +0000
Transferring IB and SC to a new computer - constant reconnecting
View Count: 2394
[2013-05-12 06:25:35] |
Jeremy A OBrien - Posts: 6 |
Hello SC staff, Thankyou for looking into my problem. Been running IB and SC for many years without major hassles. Bought a new computer which is working fine (WIN7 64) and trying to set up IB and SC exactly as they were before (old computer was vista 64). IB on new computer appears to be running fine. But then when I load SC everything is fine until I add some old data from the old SC into the new SC, including cbak,cht,stdycollct, and scid files, then IB and SC reject each other and wont stay connected. They then disconnect and reconnect every 3-4 seconds in an endless loop. This doesn't occur if there is no data in the new sc, but as soon as I add my files, even just cht and cbak files, then they wont stay connected.(I use 14 chartbooks) Here is what I think is relevant from the log. Socket closed. No error. | 2013-05-12 16:20:52 Socket shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2013-05-12 16:20:52 Connection to the service has been lost or not completed. | 2013-05-12 16:20:52 Starting TWS auto-login thread. | 2013-05-12 16:20:52 Disconnected from IB. | 2013-05-12 16:20:52 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 16:20:52 TWS auto-login thread ending. | 2013-05-12 16:20:54 Starting TWS auto-login thread. | 2013-05-12 16:20:57 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 16:20:57 The network socket is connected. | 2013-05-12 16:20:57 Using client version 46. Waiting for acceptance... | 2013-05-12 16:20:57 TWS server version: 67 | 2013-05-12 16:20:57 Connected to IB data and trade server. | 2013-05-12 16:20:57 Next valid order ID: 1 | 2013-05-12 16:20:57 Any help greatly appreciated. |
[2013-05-12 07:43:07] |
We will need to see more of the Message Log. This is not enough for us.
[2013-05-12 09:44:48] |
ok here is a lot more, but I haven't included everything cos most of it is just charts loading real fast, but not enough room here to put everything here. thx again for looking into this. Ive worked on this all weekend and cant find a solution myself. My old computer with vista still works fine but on win7 I cant get it to stay connected, with all exact same settings on IB and SC. Software version: 971 | 2013-05-12 19:27:30 Current Service Package: 3 | 2013-05-12 19:27:30 Usage end date: 2013-07-17 | 2013-05-12 19:27:30 Sierra Chart Historical Data Service is included. | 2013-05-12 19:27:30 Active service: Interactive Brokers | 2013-05-12 19:27:30 Time Zone: +10:00:00 (AEST+10AEDT+01,M10.1.0/02:00,M4.1.0/03:00) | 2013-05-12 19:27:30 2013-05-12 19:27:30 Local computer clock time | 2013-05-12 19:27:30 2013-05-12 09:27:30 GMT time | 2013-05-12 19:27:30 2013-05-12 19:27:30 Time zone adjusted time | 2013-05-12 19:27:30 Time difference to server time: 5 seconds. | 2013-05-12 19:27:30 Program path: C:\SierraChart\ | 2013-05-12 19:27:30 Data Files path: C:\SierraChart\Data\ | 2013-05-12 19:27:30 OS Version Number: 6.1 | 2013-05-12 19:27:30 Checking for large (over 100 MB) intraday data files to move data out of. Please wait.... | 2013-05-12 19:27:32 Completed checking of 222 Intraday data files (*.scid). | 2013-05-12 19:27:33 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:27:45 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:27:46 Failed to connect to the data and trade server. | 2013-05-12 19:27:46 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:27:46 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:27:46 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:27:46 Disconnected from IB. | 2013-05-12 19:27:46 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:27:46 Starting TWS auto-login thread. | 2013-05-12 19:27:49 TWS auto-login thread ending. | 2013-05-12 19:27:51 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:27:51 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:27:52 Failed to connect to the data and trade server. | 2013-05-12 19:27:52 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:27:52 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:27:52 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:27:52 Disconnected from IB. | 2013-05-12 19:27:52 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:27:52 Starting TWS auto-login thread. | 2013-05-12 19:27:53 TWS auto-login thread ending. | 2013-05-12 19:27:54 Starting TWS auto-login thread. | 2013-05-12 19:27:57 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:27:57 TWS auto-login thread ending. | 2013-05-12 19:27:58 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:27:58 Failed to connect to the data and trade server. | 2013-05-12 19:27:58 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:27:58 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:27:58 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:27:58 Disconnected from IB. | 2013-05-12 19:27:58 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:27:58 Starting TWS auto-login thread. | 2013-05-12 19:28:01 TWS auto-login thread ending. | 2013-05-12 19:28:01 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:03 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:28:04 Failed to connect to the data and trade server. | 2013-05-12 19:28:04 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:28:04 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:28:04 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:28:04 Disconnected from IB. | 2013-05-12 19:28:04 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:28:04 Starting TWS auto-login thread. | 2013-05-12 19:28:05 TWS auto-login thread ending. | 2013-05-12 19:28:05 Starting TWS auto-login thread. | 2013-05-12 19:28:09 TWS auto-login thread ending. | 2013-05-12 19:28:09 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:09 The network socket is connected. | 2013-05-12 19:28:09 Using client version 46. Waiting for acceptance... | 2013-05-12 19:28:09 TWS server version: 67 | 2013-05-12 19:28:10 Connected to IB data and trade server. | 2013-05-12 19:28:10 Next valid order ID: 1 | 2013-05-12 19:28:10 Message from IB: Connectivity between IB and Trader Workstation has been restored - data maintained.. IB Error Code: 1102. Request ID: -1. | 2013-05-12 19:28:10 Connection to the service has been lost or not completed. | 2013-05-12 19:28:10 Disconnected from IB. | 2013-05-12 19:28:10 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:28:10 Starting TWS auto-login thread. | 2013-05-12 19:28:13 TWS auto-login thread ending. | 2013-05-12 19:28:14 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:15 The network socket is connected. | 2013-05-12 19:28:15 Using client version 46. Waiting for acceptance... | 2013-05-12 19:28:15 TWS server version: 67 | 2013-05-12 19:28:15 Connected to IB data and trade server. | 2013-05-12 19:28:15 Next valid order ID: 1 | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is broken:aufarm. IB Error Code: 2103. Request ID: -1. | 2013-05-12 19:28:15 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:15 Next valid order ID: 1 | 2013-05-12 19:28:15 Starting updates for: N225M-201307-OSE.JPN | 2013-05-12 19:28:15 Subscribing to real-time True Data for symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:15 Subscribing to symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:15 HD Request # 1 - Downloading Intraday chart data for N225M-201307-OSE.JPN to the file N225M-201307-OSE.JPN.scid. Service: ib | 2013-05-12 19:28:15 HD Request # 1 - Starting date and time: 2013-05-11 04:00:00 | 2013-05-12 19:28:15 HD Request # 1 - Nothing to download. | 2013-05-12 19:28:15 HD Request # 1 - Skipping historical Intraday data download for symbol N225M-201307-OSE.JPN | 2013-05-12 19:28:15 Real-time intraday chart data file updates started for N225M-201307-OSE.JPN | 2013-05-12 19:28:15 Starting updates for: N225M-201305-OSE.JPN | 2013-05-12 19:28:15 Subscribing to real-time True Data for symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:15 Subscribing to symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:15 HD Request # 2 - Downloading Intraday chart data for N225M-201305-OSE.JPN to the file N225M-201305-OSE.JPN.scid. Service: ib | 2013-05-12 19:28:15 HD Request # 2 - Starting date and time: 2013-05-10 02:46:01 | 2013-05-12 19:28:15 HD Request # 2 - Nothing to download. | 2013-05-12 19:28:15 HD Request # 2 - Skipping historical Intraday data download for symbol N225M-201305-OSE.JPN | 2013-05-12 19:28:15 Real-time intraday chart data file updates started for N225M-201305-OSE.JPN | 2013-05-12 19:28:15 Starting updates for: ES-201306-GLOBEX | 2013-05-12 19:28:15 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:28:15 Subscribing to symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:28:15 HD Request # 3 - Downloading Intraday chart data for ES-201306-GLOBEX to the file ES-201306-GLOBEX.scid. Service: ib | 2013-05-12 19:28:15 HD Request # 3 - Starting date and time: 2013-05-11 07:15:06 | 2013-05-12 19:28:15 HD Request # 3 - Nothing to download. | 2013-05-12 19:28:15 HD Request # 3 - Skipping historical Intraday data download for symbol ES-201306-GLOBEX | 2013-05-12 19:28:15 Real-time intraday chart data file updates started for ES-201306-GLOBEX | 2013-05-12 19:28:15 Starting updates for: DIA-S-SMART | 2013-05-12 19:28:15 Subscribing to real-time True Data for symbol: DIA SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:28:15 Subscribing to symbol: DIA SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:28:15 HD Request # 4 - Downloading Intraday chart data for DIA-S-SMART to the file DIA-S-SMART.scid. Service: ib | 2013-05-12 19:28:15 HD Request # 4 - Starting date and time: 2013-05-11 07:43:06 | 2013-05-12 19:28:15 HD Request # 4 - Nothing to download. | 2013-05-12 19:28:15 HD Request # 4 - Skipping historical Intraday data download for symbol DIA-S-SMART | 2013-05-12 19:28:15 Real-time intraday chart data file updates started for DIA-S-SMART | 2013-05-12 19:28:15 ####### 150 charts load then ###### Starting updates for: NG-201310-NYMEX | 2013-05-12 19:28:16 Subscribing to real-time True Data for symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:28:16 Subscribing to symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:28:16 HD Request # 196 - Downloading Intraday chart data for NG-201310-NYMEX to the file NG-201310-NYMEX.scid. Service: ib | 2013-05-12 19:28:16 HD Request # 196 - Starting date and time: 2013-05-11 06:33:37 | 2013-05-12 19:28:16 HD Request # 196 - Nothing to download. | 2013-05-12 19:28:16 HD Request # 196 - Skipping historical Intraday data download for symbol NG-201310-NYMEX | 2013-05-12 19:28:16 Real-time intraday chart data file updates started for NG-201310-NYMEX | 2013-05-12 19:28:16 Starting updates for: SGB-201306-SGX | 2013-05-12 19:28:16 Subscribing to real-time True Data for symbol: SGB SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:28:16 Subscribing to symbol: SGB SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:28:16 HD Request # 197 - Downloading Intraday chart data for SGB-201306-SGX to the file SGB-201306-SGX.scid. Service: ib | 2013-05-12 19:28:16 HD Request # 197 - Starting date and time: 2013-05-12 16:48:16 | 2013-05-12 19:28:16 HD Request # 197 - Nothing to download. | 2013-05-12 19:28:16 HD Request # 197 - Skipping historical Intraday data download for symbol SGB-201306-SGX | 2013-05-12 19:28:16 Real-time intraday chart data file updates started for SGB-201306-SGX | 2013-05-12 19:28:16 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=173 (1). IB Error Code: 100. Request ID: 1. | 2013-05-12 19:28:16 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:16 Message from IB: Market data farm connection is broken:aufarm. IB Error Code: 2103. Request ID: -1. | 2013-05-12 19:28:16 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:17 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=234 (2). IB Error Code: 100. Request ID: 9. | 2013-05-12 19:28:17 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:17 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:18 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=267 (3). IB Error Code: 100. Request ID: 50. Symbol: EUR-201306-GLOBEX. | 2013-05-12 19:28:18 Socket closed. No error. | 2013-05-12 19:28:19 Socket shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2013-05-12 19:28:19 Connection to the service has been lost or not completed. | 2013-05-12 19:28:19 Disconnected from IB. | 2013-05-12 19:28:19 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:28:19 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:24 Starting TWS auto-login thread. | 2013-05-12 19:28:24 The network socket is connected. | 2013-05-12 19:28:24 Using client version 46. Waiting for acceptance... | 2013-05-12 19:28:24 TWS server version: 67 | 2013-05-12 19:28:24 Connected to IB data and trade server. | 2013-05-12 19:28:24 Next valid order ID: 1 | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:usfuture.il. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is broken:aufarm. IB Error Code: 2103. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:24 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:28:24 Next valid order ID: 1 | 2013-05-12 19:28:24 Starting updates for: SGXNK-201306-SGX | 2013-05-12 19:28:24 Subscribing to real-time True Data for symbol: SGXNK SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:28:24 Subscribing to symbol: SGXNK SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:28:24 HD Request # 198 - Downloading Intraday chart data for SGXNK-201306-SGX to the file SGXNK-201306-SGX.scid. Service: ib | 2013-05-12 19:28:24 HD Request # 198 - Starting date and time: 2013-05-12 16:48:15 | 2013-05-12 19:28:24 HD Request # 198 - Nothing to download. | 2013-05-12 19:28:24 HD Request # 198 - Skipping historical Intraday data download for symbol SGXNK-201306-SGX | 2013-05-12 19:28:24 Real-time intraday chart data file updates started for SGXNK-201306-SGX | 2013-05-12 19:28:24 Starting updates for: JGB-201306-TSEJ | 2013-05-12 19:28:24 Subscribing to real-time True Data for symbol: JGB SecType: FUT Exchange: TSEJ Currency: | 2013-05-12 19:28:24 Subscribing to symbol: JGB SecType: FUT Exchange: TSEJ Currency: | 2013-05-12 19:28:24 HD Request # 199 - Downloading Intraday chart data for JGB-201306-TSEJ to the file JGB-201306-TSEJ.scid. Service: ib | 2013-05-12 19:28:24 HD Request # 199 - Starting date and time: 2013-05-12 16:48:16 | 2013-05-12 19:28:24 HD Request # 199 - Nothing to download. | 2013-05-12 19:28:24 HD Request # 199 - Skipping historical Intraday data download for symbol JGB-201306-TSEJ | 2013-05-12 19:28:24 Real-time intraday chart data file updates started for JGB-201306-TSEJ | 2013-05-12 19:28:24 Starting updates for: N225M-201306-OSE.JPN | 2013-05-12 19:28:24 Subscribing to real-time True Data for symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:24 Subscribing to symbol: N225M SecType: FUT Exchange: OSE.JPN Currency: | 2013-05-12 19:28:24 HD Request # 200 - Downloading Intraday chart data for N225M-201306-OSE.JPN to the file N225M-201306-OSE.JPN.scid. Service: ib | 2013-05-12 19:28:24 HD Request # 200 - Starting date and time: 2013-05-12 16:48:16 | 2013-05-12 19:28:24 HD Request # 200 - Nothing to download. | 2013-05-12 19:28:24 HD Request # 200 - Skipping historical Intraday data download for symbol N225M-201306-OSE.JPN | 2013-05-12 19:28:24 Real-time intraday chart data file updates started for N225M-201306-OSE.JPN | 2013-05-12 19:28:24 Starting updates for: NZD-201306-GLOBEX | 2013-05-12 19:28:24 Subscribing to real-time True Data for symbol: NZD SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:28:24 Subscribing to symbol: NZD SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:28:24 HD Request # 201 - Downloading Intraday chart data for NZD-201306-GLOBEX to the file NZD-201306-GLOBEX.scid. Service: ib | 2013-05-12 19:28:24 HD Request # 201 - Starting date and time: 2013-05-11 06:54:20 | 2013-05-12 19:28:24 HD Request # 201 - Nothing to download. | 2013-05-12 19:28:24 HD Request # 201 - Skipping historical Intraday data download for symbol NZD-201306-GLOBEX | 2013-05-12 19:28:24 Real-time intraday chart data file updates started for NZD-201306-GLOBEX | 2013-05-12 19:28:24 ###### then another 180 load ####### Real-time intraday chart data file updates started for STW-S-ASX | 2013-05-12 19:28:25 Starting updates for: NG-201307-NYMEX | 2013-05-12 19:28:25 Subscribing to real-time True Data for symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:28:25 Subscribing to symbol: NG SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:28:25 HD Request # 394 - Downloading Intraday chart data for NG-201307-NYMEX to the file NG-201307-NYMEX.scid. Service: ib | 2013-05-12 19:28:25 HD Request # 394 - Starting date and time: 2013-05-11 07:14:33 | 2013-05-12 19:28:25 HD Request # 394 - Nothing to download. | 2013-05-12 19:28:25 HD Request # 394 - Skipping historical Intraday data download for symbol NG-201307-NYMEX | 2013-05-12 19:28:25 Real-time intraday chart data file updates started for NG-201307-NYMEX | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125688590. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113322514. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 122385424. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125040278. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 116544617. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 47195984. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 104238112. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 76117638. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 110604432. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113866582. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 105383650. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 105383655. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 47506666. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 104813149. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 118903158. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39622943. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 104210818. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 109331521. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 121936175. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108733449. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 98887602. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 104238122. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108816234. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 43635367. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 56347254. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39039301. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 8991352. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 42922245. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 42751758. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 51029786. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 43661924. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 97276826. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114091271. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 124939018. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39256163. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 106853178. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125040281. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113322495. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114533926. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 122354742. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108858082. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114533598. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 119592440. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 109331524. | 2013-05-12 19:28:25 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=293 (2). IB Error Code: 100. Request ID: 9. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11289568. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11294204. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11910870. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108822306. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 3882741. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 7202087. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 15547841. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114091283. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 56238873. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 41051204. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 44569426. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4109645. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4036833. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4036818. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 41881274. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125040284. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113917744. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113981860. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108816224. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114929756. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 124938993. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 74110186. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 124939003. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 51822411. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113322508. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 124197795. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4036823. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 103932983. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 12101107. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4109654. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125040288. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 47207284. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 118903121. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 118903177. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 98887553. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 118903041. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 98887482. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 79342377. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 756733. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 40800182. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 9579970. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39881200. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 55679435. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4215217. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4109712. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4081863. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 47028156. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 29598150. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4109697. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 109331534. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 50530896. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 113786584. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 109331531. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 112897988. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 52253192. | 2013-05-12 19:28:26 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=265 (3). IB Error Code: 100. Request ID: 50. Symbol: DIA-S-SMART. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 84696719. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 42808817. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39881195. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 55679438. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 84696744. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 38590758. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 42393358. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 40413278. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 75961365. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 84702208. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114091272. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 4215220. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 53011465. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 48168448. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 44569526. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 56935162. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 117863437. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 115916916. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 119185531. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 12294108. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 95348450. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 52997874. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 91884262. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 96853714. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 74262522. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 67531165. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 32237620. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 102194440. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 106853197. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 97276835. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 59354082. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 51529211. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 49330120. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 84696688. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 39851366. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 46943346. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 50918095. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 106779903. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 52433593. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 125373039. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 114150512. | 2013-05-12 19:28:27 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 77059513. | 2013-05-12 19:28:27 Socket closed. No error. | 2013-05-12 19:28:27 Socket shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2013-05-12 19:28:27 Connection to the service has been lost or not completed. | 2013-05-12 19:28:27 Disconnected from IB. | 2013-05-12 19:28:27 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:28:27 Starting TWS auto-login thread. | 2013-05-12 19:28:28 TWS auto-login thread ending. | 2013-05-12 19:28:28 File >> Disconnect selected. | 2013-05-12 19:28:31 Reconnect canceled. | 2013-05-12 19:28:31 Disconnected from IB. | 2013-05-12 19:28:31 Active service: Interactive Brokers | 2013-05-12 19:28:44 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:53 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:28:54 Failed to connect to the data and trade server. | 2013-05-12 19:28:54 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:28:54 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:28:54 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:28:54 Disconnected from IB. | 2013-05-12 19:28:54 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:28:54 Starting TWS auto-login thread. | 2013-05-12 19:28:57 TWS auto-login thread ending. | 2013-05-12 19:28:59 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:28:59 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:29:00 Failed to connect to the data and trade server. | 2013-05-12 19:29:00 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:29:00 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:29:00 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:29:00 Disconnected from IB. | 2013-05-12 19:29:00 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:29:00 Starting TWS auto-login thread. | 2013-05-12 19:29:01 TWS auto-login thread ending. | 2013-05-12 19:29:02 Starting TWS auto-login thread. | 2013-05-12 19:29:05 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:29:05 TWS auto-login thread ending. | 2013-05-12 19:29:06 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:29:06 Failed to connect to the data and trade server. | 2013-05-12 19:29:06 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:29:06 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:29:06 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:29:06 Disconnected from IB. | 2013-05-12 19:29:06 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:29:06 Starting TWS auto-login thread. | 2013-05-12 19:29:09 TWS auto-login thread ending. | 2013-05-12 19:29:10 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:29:11 Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-05-12 19:29:12 Failed to connect to the data and trade server. | 2013-05-12 19:29:12 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-05-12 19:29:12 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-05-12 19:29:12 To prevent further connection attempts, select File >> Disconnect. | 2013-05-12 19:29:12 Disconnected from IB. | 2013-05-12 19:29:12 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:29:12 Starting TWS auto-login thread. | 2013-05-12 19:29:13 TWS auto-login thread ending. | 2013-05-12 19:29:13 Starting TWS auto-login thread. | 2013-05-12 19:29:17 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:29:17 The network socket is connected. | 2013-05-12 19:29:17 Using client version 46. Waiting for acceptance... | 2013-05-12 19:29:17 TWS server version: 67 | 2013-05-12 19:29:17 Connected to IB data and trade server. | 2013-05-12 19:29:17 Next valid order ID: 1 | 2013-05-12 19:29:17 Starting updates for: CL-201306-NYMEX | 2013-05-12 19:29:17 Subscribing to real-time True Data for symbol: CL SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:29:17 Subscribing to symbol: CL SecType: FUT Exchange: NYMEX Currency: | 2013-05-12 19:29:17 HD Request # 395 - Downloading Intraday chart data for CL-201306-NYMEX to the file CL-201306-NYMEX.scid. Service: ib | 2013-05-12 19:29:17 HD Request # 395 - Starting date and time: 2013-05-11 07:15:05 | 2013-05-12 19:29:17 HD Request # 395 - Nothing to download. | 2013-05-12 19:29:17 HD Request # 395 - Skipping historical Intraday data download for symbol CL-201306-NYMEX | 2013-05-12 19:29:17 Real-time intraday chart data file updates started for CL-201306-NYMEX | 2013-05-12 19:29:17 Next valid order ID: 1 | 2013-05-12 19:29:17 Starting updates for: EUR-201306-GLOBEX | 2013-05-12 19:29:17 Subscribing to real-time True Data for symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:29:17 Subscribing to symbol: EUR SecType: FUT Exchange: GLOBEX Currency: | 2013-05-12 19:29:17 HD Request # 396 - Downloading Intraday chart data for EUR-201306-GLOBEX to the file EUR-201306-GLOBEX.scid. Service: ib | 2013-05-12 19:29:17 HD Request # 396 - Starting date and time: 2013-05-11 04:18:23 | 2013-05-12 19:29:17 HD Request # 396 - Nothing to download. | 2013-05-12 19:29:17 HD Request # 396 - Skipping historical Intraday data download for symbol EUR-201306-GLOBEX | 2013-05-12 19:29:17 Real-time intraday chart data file updates started for EUR-201306-GLOBEX | 2013-05-12 19:29:17 ###### then another 180 load ##### Real-time intraday chart data file updates started for VIX-201307-CFE | 2013-05-12 19:29:18 Starting updates for: XLF-S-SMART | 2013-05-12 19:29:18 Subscribing to real-time True Data for symbol: XLF SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:29:18 Subscribing to symbol: XLF SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:29:18 HD Request # 591 - Downloading Intraday chart data for XLF-S-SMART to the file XLF-S-SMART.scid. Service: ib | 2013-05-12 19:29:18 HD Request # 591 - Starting date and time: 2013-05-11 07:26:06 | 2013-05-12 19:29:18 HD Request # 591 - Nothing to download. | 2013-05-12 19:29:18 HD Request # 591 - Skipping historical Intraday data download for symbol XLF-S-SMART | 2013-05-12 19:29:18 Real-time intraday chart data file updates started for XLF-S-SMART | 2013-05-12 19:29:18 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:20 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=109 (1). IB Error Code: 100. Request ID: 1. | 2013-05-12 19:29:20 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:20 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=274 (2). IB Error Code: 100. Request ID: 9. | 2013-05-12 19:29:20 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:20 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: Market data farm connection is broken:aufarm. IB Error Code: 2103. Request ID: -1. | 2013-05-12 19:29:21 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=203 (3). IB Error Code: 100. Request ID: 50. Symbol: TYO-S-SMART. | 2013-05-12 19:29:22 Message from IB: Market data farm connection is OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:22 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:22 Socket closed. No error. | 2013-05-12 19:29:22 Socket shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2013-05-12 19:29:22 Connection to the service has been lost or not completed. | 2013-05-12 19:29:22 Disconnected from IB. | 2013-05-12 19:29:22 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-12 19:29:22 Connecting to IB data and trade server: localhost port 7496... | 2013-05-12 19:29:27 Starting TWS auto-login thread. | 2013-05-12 19:29:27 The network socket is connected. | 2013-05-12 19:29:27 Using client version 46. Waiting for acceptance... | 2013-05-12 19:29:27 TWS server version: 67 | 2013-05-12 19:29:27 Connected to IB data and trade server. | 2013-05-12 19:29:27 Next valid order ID: 1 | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:hkfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is broken:aufarm. IB Error Code: 2103. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:27 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2013-05-12 19:29:27 Next valid order ID: 1 | 2013-05-12 19:29:27 Starting updates for: SGXNK-201306-SGX | 2013-05-12 19:29:27 Subscribing to real-time True Data for symbol: SGXNK SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:29:27 Subscribing to symbol: SGXNK SecType: FUT Exchange: SGX Currency: | 2013-05-12 19:29:27 HD Request # 592 - Downloading Intraday chart data for SGXNK-201306-SGX to the file SGXNK-201306-SGX.scid. Service: ib | 2013-05-12 19:29:27 HD Request # 592 - Starting date and time: 2013-05-12 19:28:25 | 2013-05-12 19:29:27 HD Request # 592 - Nothing to download. | 2013-05-12 19:29:27 HD Request # 592 - Skipping historical Intraday data download for symbol SGXNK-201306-SGX | 2013-05-12 19:29:27 Real-time intraday chart data file updates started for SGXNK-201306-SGX | 2013-05-12 19:29:27 Starting updates for: WDC-S-ASX | 2013-05-12 19:29:27 Subscribing to real-time True Data for symbol: WDC SecType: STK Exchange: ASX Currency: | 2013-05-12 19:29:27 Subscribing to symbol: WDC SecType: STK Exchange: ASX Currency: | 2013-05-12 19:29:27 HD Request # 593 - Downloading Intraday chart data for WDC-S-ASX to the file WDC-S-ASX.scid. Service: ib | 2013-05-12 19:29:27 HD Request # 593 - Starting date and time: 2013-05-10 17:36:36 | 2013-05-12 19:29:27 HD Request # 593 - Nothing to download. | 2013-05-12 19:29:27 HD Request # 593 - Skipping historical Intraday data download for symbol WDC-S-ASX | 2013-05-12 19:29:27 Real-time intraday chart data file updates started for WDC-S-ASX | 2013-05-12 19:29:27 Starting updates for: SCO-S-SMART | 2013-05-12 19:29:27 Subscribing to real-time True Data for symbol: SCO SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:29:27 Subscribing to symbol: SCO SecType: STK Exchange: SMART Currency: USD | 2013-05-12 19:29:27 HD Request # 594 - Downloading Intraday chart data for SCO-S-SMART to the file SCO-S-SMART.scid. Service: ib | 2013-05-12 19:29:27 HD Request # 594 - Starting date and time: 2013-05-11 07:04:28 | 2013-05-12 19:29:27 HD Request # 594 - Nothing to download. | 2013-05-12 19:29:27 HD Request # 594 - Skipping historical Intraday data download for symbol SCO-S-SMART | 2013-05-12 19:29:27 Real-time intraday chart data file updates started for SCO-S-SMART | 2013-05-12 19:29:27 then it just keeps looping around like this every 5 seconds. reconnects then disconnects etc |
[2013-05-13 02:29:26] |
ok, solved for the moment. But im not sure how. It was either some old etfs that should have read XXX-S-ARCA instead of xxx-s-smart. Or I changed some settings including 'Delay between Historical Data requests' to over 10secs. Anyway Ill let you know if the issue returns, thx. |
[2013-05-13 03:09:39] |
Based upon the following messages: 25
Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 119592440. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 109331524. | 2013-05-12 19:28:25 Message from IB: Max rate of messages per second has been exceeded:max=50 rec=293 (2). IB Error Code: 100. Request ID: 9. | 2013-05-12 19:28:25 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11289568. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11294204. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 11910870. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 108822306. | 2013-05-12 19:28:26 Message from IB: Invalid Real-time Query:Historical data request pacing violation. IB Error Code: 420. Request ID: 3882741. | 2013-05-12 19:28:26 It is clear that there are too many data requests occurring over short period of time. So you have to increase the Delay Between Historical Data Requests which you have done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-13 11:53:27] |
User36173 - Posts: 12 |
You need DTN/IQFeed with so many charts.
