Date/Time: Wed, 25 Nov 2026 21:06:09 +0000
how to set the color with regards to value in subchart
View Count: 438
| [2025-06-20 00:13:26] |
| User328032 - Posts: 1 |
Hi, may I know how to setup; for gradient the background color of subchart according to e.g vol /delta the higher the value, the darker is the background for instance. and anyway to set the range for it? let say vol 0-500 for one color grade, 501-1000 is another .etc |
| [2025-06-20 14:36:52] |
| John - SC Support - Posts: 48659 |
For the Numbers Bars Calculated Values study, there is the capability to color the background based on the percentage of the maximum value for the row. Refer to the following: Numbers Bars: Color Background Based on Value Percentage There is not a way to control this based on specific value ranges. If you are wanting to color the background of the chart based on some particular item, then let us know and we can give you a way to do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
