Date/Time: Wed, 18 Nov 2026 09:39:34 +0000
Color Bar Based on Alert Condition - Time Constraint?
View Count: 800
[2025-06-19 10:00:52]
User753526 - Posts: 87
I am using the Color Bar Based on Alert Condition with the Alert code
(C>(ABS(H-L)*.95)+L
which works fine. However, is it possible to constrain this to only alert and display the alert on the chart between two times? 09.30 and 12.00?
[2025-06-19 16:11:33]
Time conditions are most easily entered by using the BARTIME and TIME() functions. Refer to the following:
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#TIME_Function
For instance, to check if a bar opened after 09:30, you would enter the following:
=BARTIME > TIME(09, 30, 00)
To combine items, you need to use the AND() and/or OR() functions. Refer to the following:
Study/Chart Alerts And Scanning: OR and AND Functions
Therefore, to get what you want, your formula would be the following:
=AND((C>(ABS(H-L)*.95)+L, BARTIME > TIME(09, 30, 00), BARTIME < TIME(12, 00, 00))
Note that you can change the Greater Than and Less Than to be Greater Than or Equal To, if you want to be inclusive the time (i.e. BARTIME >= TIME(09, 30, 00))
