Date/Time: Wed, 25 Nov 2026 21:05:58 +0000
An access for only one pc
View Count: 501
[2025-06-19 00:38:17]
User660392 - Posts: 62
I have an access for both my pc`s to Sierra chart ,graphs and real time data with number 10 package which i have. Now i want to reverse it back only for one pc , so i would pay only for one computer the real time data , how can i do that & and make sure the pc that i want to disconnect will be the right one?
Thank You.
[2025-06-19 14:13:07]
John - SC Support - Posts: 48659
We have gone ahead and changed your exchange option to only get data to 1 computer. Note that this change will actually occur at the next renewal on July 1, 2025. Until then, you will still have access to the data to two computers at the same time. The control for this is at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
As to which computer will get the data, it is about which system connects first. If you will only be using a single computer going forward, then it really does not matter. But if you move back and forth between the two, but will only have one connected at a time, then you just need to ensure that you have exited from Sierra Chart on the system you are not using.
