Date/Time: Wed, 25 Nov 2026 21:06:10 +0000
Keep fib numbers in view
View Count: 530
| [2025-06-18 19:11:15] |
| User357195 - Posts: 204 |
How do I keep the Fib levels visible at the left edge of a chart. I have set the levels and asked SC to display their respective percent and price; but, I can't find how to keep the percent and price always visible for each level on the left edge of a chart as a symbol trades and builds more candlesticks.
| [2025-06-18 19:38:03] |
| John - SC Support - Posts: 48659 |
If you are using the "Price Retracement", "Price Expansion", or "Price Projection" tools, then if you set the option for "Extend Left" then the values will continue to display on the left edge of the chart as the drawing itself is moved off the graphics area. Refer to the "Extend Left" item in this section: Chart Drawing Tools: Price Retracement | Price Expansion | Price Projection Configuration Note that you do need to have the "Multiplier" set to 0 for this to work as you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
