Date/Time: Wed, 25 Nov 2026 21:06:07 +0000
AMP Futures - Teton CME Data Service Issue
View Count: 727
| [2025-06-18 13:58:03] |
| User269718 - Posts: 4 |
I was set up on AMP Futures and trying to connect to Teton CME Routing and am getting "Connection error No trade accounts assigned. I contacted AMP and they said to contact Sierra Chart support everything on their end is setup already.
| [2025-06-18 15:54:48] |
| John - SC Support - Posts: 48659 |
If AMP tells you that the account is setup and you are still getting the "No Trade Accounts Assigned" error, then the first thing to check is that you have the correct "Clearing Firm" selected in your "Data/Trade Service Settings". Please refer to Step #9 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions If the Clearing Firm is set correctly then you need to get back with AMP and have them verify that the setup is complete. Also ask them to check that the Account Name has been entered correctly on their end, as the Account Name is what is used to connect your Sierra Chart software with your AMP account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
