Date/Time: Wed, 25 Nov 2026 21:05:55 +0000
Account Management - User P/L management
View Count: 564
| [2025-06-18 10:29:33] |
| User687917 - Posts: 84 |
Hi, I watch this video of Sierra Chart User Profit/loss management https://www.youtube.com/watch?v=iAAmJqltGSg I follow the steps to set parameters and then "Commit" and "Update", but there is no update of any parameter at lower part of window, as the video shows The steps i folow: - Set the profit and Loss values and flatten or liquidation mode - Click on "Commit this tab" - Click on "Update" button Result: Not update parameters * If the attached image couldn't see, i've upload it to Imgur https://imgur.com/BkQ02ve |
Attachment Deleted. |
| [2025-06-18 13:08:58] |
| Sierra_Chart Engineering - Posts: 25483 |
This feature can only be used, by the trading evaluator services: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-18 14:00:32] |
Can't this work using Teton Order routing? Is it too complicated to activate this on an account-by-account basis, instead of having to use Global Profit/Loss Management? It would be interesting to be able to activate this, and in addition, to add some security layer to avoid disabling it (by self sabotage), such as adding a password or similar. |
| [2025-06-18 15:56:52] |
| John - SC Support - Posts: 48659 |
At one point we were making this available with Teton, but due to exchange rules with the data, we had to stop. It is not something we are happy about, but we have to comply with the exchanges. Therefore, the only option for live trading P/L management from Sierra Chart is the built in "Global Profit/Loss Management". Refer to the following: Global Profit/Loss Management For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
