Date/Time: Wed, 25 Nov 2026 21:06:07 +0000
Numbers Bars study pullback column, highlighting volume point of control
View Count: 688
[2025-06-16 19:01:46]
robrg2675 - Posts: 22
Hello. When displaying the pullback column on the Numbers Bars study, is it possible to highlight the volume point of control (VPOC) for the pullback column? I have it set so that the VPOC is highlighted (column 1), but this does not highlight the VPOC on the pullback column. If the pullback column retraces to the price level where the VPOC is currently located for the bar, the highlighting appears at that level, but it is not at the VPOC for the pullback; rather, it is at the level where the candle's VPOC is.
[2025-06-17 14:37:23]
John - SC Support - Posts: 48659
There is no support for highlighting the POC of the Pullback Column. This would be something we would have to change, so we have noted this as a Feature Request.
You can, however, use the "Highlight Maximum Volume In" Input to get the POC for the Pullback Column. You will just have to be a bit careful with how the Min/Max volume is defined. Refer to the following:
Numbers Bars: Highlight Maximum Value In
Numbers Bars: Highlight Maximum/Minimum Value Based On
