Date/Time: Wed, 25 Nov 2026 21:06:19 +0000
Gold futures symbol
View Count: 2062
| [2025-06-16 14:48:26] |
| User360283 - Posts: 538 |
What is the Gold futures symbol? Thanks |
| [2025-06-16 16:22:12] |
| John - SC Support - Posts: 48659 |
The exact symbol depends on the service you are connected to. The "File >> Find Symbol" window takes care of translating the symbols based on the service you are connected to, so always look for the symbol in that window. Refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-16 17:04:45] |
Where on my Renko charts is Find File"
| [2025-06-16 18:27:55] |
| User135243 - Posts: 337 |
GCG25 (Denali) or GCG5 (Rithmic) and "File" you can find on the top left side of the software |
| [2025-06-17 17:23:51] |
| Sierra_Chart Engineering - Posts: 25483 |
Refer to: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
