Date/Time: Wed, 25 Nov 2026 21:06:21 +0000
Chartbook on Another Screen
View Count: 466
| [2025-06-15 20:09:23] |
| Cileron - Posts: 52 |
I know you can detach a chart window and drag it to another screen but can you do the same for a whole chart book? If possible i would like to have a chart book on another screen so i can switch between the charts on that screen only. |
| [2025-06-16 15:07:05] |
| John - SC Support - Posts: 48659 |
To do this you need to start a "New Instance" of Sierra Chart. Then you can have the entire workbook in that instance. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
