Date/Time: Mon, 29 Apr 2024 08:59:13 +0000
Server side OCO and Bracket orders for Rithmic for OptimusTrading customers
View Count: 1031
[2014-10-03 17:53:25] |
User692964 - Posts: 17 |
I have received an email from OptimusFutures that Server side OCO and Bracket orders are now available through Rithmic exclusive for OptimusTrading customers. Can you please confirm this and if yes which version should I be using for it ? I have version 1190
[2014-10-03 17:56:17] |
Please ignore my post as I read the post about the confirmation of the same in another thread
[2014-10-03 18:33:32] |
Server-side OCO's are supported. Not a full bracket order. However, an OCO is used with a bracket order . So when the parent order fills, an OCO order is sent at that time that is server-side managed.
