Date/Time: Thu, 02 May 2024 11:42:36 +0000
Can't run 2 instances of Sierra Charts
View Count: 1503
[2013-05-12 05:47:30] |
lespaul - Posts: 5 |
Hello I'm running sierra on my desktop and when I try to run it on my labtop at the same time it disconnects my desktop and then connects the labtop i thought you could have 2 instances of Sierra?
[2013-05-12 07:41:33] |
You can use Sierra Chart on 2 different systems at the same time, but the OEC service that you are using, is clearly limiting you to one connection. So you will need to contact OEC about this.
