Date/Time: Wed, 25 Nov 2026 21:06:02 +0000
bar value
View Count: 533
[2025-06-11 17:33:26]
User577837 - Posts: 8
Would there be a setting that I can activate to show a bars value (OHLC), at the top of the screen, when hovering over it with the crosshair? The area I'm talking about is shown on the attached.
Thank you!
imageCapture.PNG / V - Attached On 2025-06-11 17:33:21 UTC - Size: 25.42 KB - 235 views
[2025-06-11 17:35:03]
John - SC Support - Posts: 48659
There is not an option directly as you have asked for it.
But, the "Compact Tool Values Window" can be set to display horizontally, and you can position it to be at, or near, the place you are wanting it. This will give you what you are looking for. Refer to the following:
Chart Drawing Tools: Compact Tool Values Window
