Date/Time: Wed, 25 Nov 2026 21:06:04 +0000
Need Help getting live quotes on Denali Sierra Charts
View Count: 498
| [2025-06-11 16:59:16] |
| User249200 - Posts: 3 |
I paid for live data with CQG but I would like use Denali for my live quotes. I don't seem to be getting live quotes, where am I going wrong, just looking for some help here. Thanks
| [2025-06-11 18:41:12] |
| John - SC Support - Posts: 48659 |
Everything looks good on your account, so you should be getting real-time data for the CME Group. If you are still having an issue, then please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
