Date/Time: Wed, 25 Nov 2026 21:24:14 +0000
ratio
View Count: 494
| [2025-06-10 14:57:48] |
| User220939 - Posts: 65 |
Hi, in a candle, I would like to show the following ratio: - in a green candle, divide the second lowest bid by the lowest bid - in a red candle, divide the second highest ask by the highest ask. Is there a study to do this? |
| [2025-06-10 16:02:58] |
Attached is a Study Collection that does this. Modify as you need to. Refer to the following for how to use a Study Collection provided by Support: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-11 06:13:29] |
Hi, the study does not work |
| [2025-06-11 14:29:56] |
Attached is an image of what we see when we add the Study Collection to a chart. What do you see? What are you getting? What is not working?
| [2025-06-11 14:34:22] |
after several attempts it works, thank you very much
