Date/Time: Wed, 25 Nov 2026 21:23:50 +0000
Transparent Fill bottom and top
View Count: 1175
| [2025-06-09 15:06:28] |
| Steve Leon - Posts: 319 |
would you explain what the difference is between transparent fill top and bottom and also the difference between transparent fila and transparent fill rectangle. i am using the the session indicator in chart region number one of the chart. how can i display the indicator in regions number 2,3 and so on. I thought initially this could be controlled by fill top and bottom but i dont think i am understanding how these graphics work. I did try to figure this out by searching the documentation and using google. Thank you |
| [2025-06-09 17:45:57] |
Refer to the following for what the Top and Bottom drawing pairs are about: Chart Studies: Notes about Top and Bottom Draw Style Pairs Refer to the following for how to set the region in which a study is displayed: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
