Date/Time: Wed, 25 Nov 2026 21:24:11 +0000
%Volume next to eachline of TPO
View Count: 552
| [2025-06-07 10:21:13] |
| User941553 - Posts: 1 |
Hello, is there a way with the basic TPO chart to get a line with the %¨Volume for each line of tpo next to the profile of the day, or do i have to code it ? Thanks I attached the exact picture of what i want to do ( the %vol column in the center next to the profile) |
Attachment Deleted. Private File |
| [2025-06-09 15:53:00] |
There is not a way to have it on the left, but you can have it to the right of the TPO. You need to add a Volume by Price study to the chart and display the volumes in the bars and then set the transparency for the bars to 100% so you do not see the bars. Attached is a Study Collection that does this. Refer to the following for how to use it: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
