Date/Time: Wed, 25 Nov 2026 21:23:50 +0000
multi time frame chart
View Count: 855
| [2025-06-06 14:30:09] |
| coachted - Posts: 545 |
Is there a way I can have a 15 min candles chart contain 1 min candles as well? Please see attached example...to the right is the higher time frame and to the left is the lower time frame
| Attachment Deleted. |
| [2025-06-06 15:31:33] |
There is not a way to have the two time frames displayed as you reference on a single chart. But you can have two charts that are next to each other to accomplish this. In terms of overlaying a higher time frame onto a lower one, refer to the following Input for the "Study/Price Overlay": Study/Price Overlay Study: Use Multicolumn Rectangle Style for Price Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-07 08:46:56] |
| Sébastien - Posts: 156 |
Here is a tutorial to achieve what you want : https://www.youtube.com/watch?v=qwXE4e1Zwog But as John said, you need 2 charts, but one can be hidden. |
| [2025-06-09 15:19:56] |
Thank you Sebastien, we will have to remember this concept. We had not thought of it.
| [2025-06-09 16:00:50] |
Hey Sebastian...thank you so much this is exactly what i was looking for ...really appreciate your help
