Date/Time: Sun, 05 May 2024 06:59:55 +0000
UseTool qstn
View Count: 1222
[2014-10-02 21:51:30] |
ganz - Posts: 1048 |
Hello Support. I'm trying to rewrite my ZZ oscilator for the new ZZ. Everything is OK but a strange UseTool issue takes place. There are some digits series from 0 to 9 at the very left edge of a region. Is it because of me or is it an issue? thnx. http://s10.postimg.org/6zgqew4yx/zz1.png http://s10.postimg.org/pt2jbw36x/zz2.png Date Time Of Last Edit: 2014-10-02 22:02:51
[2014-10-03 04:38:30] |
There must be something you are doing to put those there.
[2014-10-03 22:37:53] |
SC Support Hm...m 1) v1199 If I set CalcMode from 1 to 3 then the issue has gone. 2) v1154 The study/settings are the same as in the post #1 http://s22.postimg.org/5nbhjk9fl/zz3.png My "ZZ oscillator" is based on the ZZ from studies7.cpp: I've added a histogram and numbers using UseTool. Nothing more. |
[2014-10-05 23:52:07] |
SC Support I've got rid of my own markers and the issue isn't there now. The study was shared on BMT if someone is interested in https://www.bigmiketrading.com/sierra-chart/26525-zigzag-swing-histogram-6.html#post440576 |
[2014-10-06 05:59:49] |
U_winks - Posts: 190 |
Thanks very much, ganz! :)
