Date/Time: Wed, 25 Nov 2026 21:24:03 +0000
Order allocation problem using copy trader
View Count: 572
[2025-06-05 15:48:25]
sadramistes - Posts: 24
Hi, i try to use the SC copy trader to allocate my trades across two topstep accounts. My SC version is 2726 (64-bits).
More specifically, i want to use the account ending in 0242 as the mother one and the account ending in 3259 as the child one.
When i choose the 0242 then when i open the arrow to choose the child account it comes up empty.
How can i fix this problem?
imageScreenshot 2025-06-05 161613.png / V - Attached On 2025-06-05 15:48:15 UTC - Size: 35.33 KB - 331 views
[2025-06-05 16:33:58]
You need to add the account to want to copy to in the top of that page. So where you currently have the 0242 account selected, you need to select the 3259 account, and then select the "Add" button just under it. Then the 3259 account will be in the list of accounts to be copied to. Refer to the instructions here:
Order Allocation to Trade Accounts: Setup Instructions
