Date/Time: Wed, 25 Nov 2026 21:23:59 +0000
Minimum Maximum Value
View Count: 733
| [2025-06-04 20:17:54] |
| cmack1011 - Posts: 201 |
I currently have the "Minimum" and "Maximum" values highlight on this Numbers Bar column. However, as you can see, the highlights are not highlighting the actual minimum and maximum amounts in the bar. The bar is Delta Profile. Thank you.
| [2025-06-04 21:16:36] |
The particular item that highlighted by the "Minimum and Maximum" values is defined by the following Input: Numbers Bars: Highlight Maximum/Minimum Value Based On Make sure this is set as you want. It does not need to match what is displayed in the bars. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
