Date/Time: Wed, 25 Nov 2026 21:23:53 +0000
Problem with MarketDepthHistoricalChart
View Count: 750
[2025-06-01 18:58:51]
User138602 - Posts: 185
I have 2 Charts with the marketdepth indicator....1min and 10sec. I use the same indicator settings for both charts.
The problem is the study coloring output on the charts is totally different between those 2 charts UNTIL i change the 10sec chart to a minimum 20sec bar peroid.
Why is this? If you want i can attach some screenshots.
[2025-06-01 19:59:24]
Make sure this Input is set to All Bars:
Market Depth Historical Graph: Determine Min and Max Levels from All Bars or Visible Bars
Set this Input to No:
Market Depth Historical Graph: Use Last Quantity Instead Of Max Quantity For Bars
And make sure each chart is set to load the exact amount of data. Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
Would be best to close one of the charts and duplicate one from the other.
Date Time Of Last Edit: 2025-06-01 20:00:40
