Date/Time: Wed, 25 Nov 2026 21:23:56 +0000
Time and sales data in text file export
View Count: 3182
| [2025-05-30 18:54:16] |
| R10 - Posts: 18 |
Hi, i replayed specific parts of a chart looking at the time and sales window and i would like to export that data lets say may 28 from 9am to 10am and have what i see on the T&S window as a text file with all the fetaures Time, price, volume,bid/asksizes etc. Could someone help me do it or can i only get a text file doing the 1 tick data method? |
| [2025-05-30 19:14:49] |
There is no option for exporting the Time and Sales data. You would need to create a custom study to do what you want and access the Time and Sales through that. Refer to the following: ACSIL Interface Members - Functions: sc.GetTimeAndSales() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php The other option is to export the intraday data file. To do this, use "Edit >> Export Intraday Data to Text File". Refer to the following: Edit Menu: Edit >> Export Intraday Data to Text file If your data is stored at 1 tick increments, then this will give you every trade, so the trade information will match up, but Bid Size, Ask Size and Number of Trades will not be present. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-30 19:21:05] |
| R10 - Posts: 18 |
Thanks John for the quick reply, i will maybe ask Chatgpt if they can help me out with the coding, but if not then i will do what you wrote down for the other option and do it with the 1 tick increments. Best regards and have a nice day! |
