Date/Time: Wed, 25 Nov 2026 21:35:51 +0000
Separate Pocs for Bid and Ask?
View Count: 744
| [2025-05-28 18:45:10] |
| TacoSalad - Posts: 1 |
I was wondering if it’s possible to do something like this in the number bars study, where the bid and ask max values are highlighted separately instead of just one POC. I looked around but couldn’t figure out whether this option exists.
| Attachment Deleted. |
| [2025-05-28 20:49:23] |
There is not a direct way to do this. So we have marked this as a Feature Request to add the option for highlighting Maximum value in a column for both Bid and Ask when displaying the values as "Bid x Ask". But, there is a workaround, although not perfect. It requires the use of 2 Numbers Bars studies with two columns displayed in each, then you can highlight the Bid in Column 1, and the Ask in Column 2. When you do this, the setup between the two studies has to be identical, at least in terms of the columns and what is displayed. Attached is a Study Collection that does this with no background coloring. Refer to the following for how to use this: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
