Date/Time: Wed, 25 Nov 2026 21:35:52 +0000
The price on the VPS is not updating
View Count: 744
[2025-05-26 16:05:45]
User189129 - Posts: 4
The price updates work correctly on my PC, but when I switch to my VPS, no price updates occur. Here are some logs.
2025-05-26 11:55:08.063 | Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 443
2025-05-26 11:55:08.064 | DTC Client socket (3) | Creating socket.
2025-05-26 11:55:08.064 | DTC Client socket (3) | New receive buffer size: 0
2025-05-26 11:55:08.064 | DTC Client socket (3) | Connecting to IP: 69.39.70.246.
2025-05-26 11:55:11.478 | DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2025-05-26 11:55:11.478 | DTC Client socket (3) | CloseSocket call.
2025-05-26 11:55:11.478 | Denali Data Feed | Failed connections: 290
2025-05-26 11:55:11.478 | DTC Client socket (0) | CloseSocket call.
2025-05-26 11:55:11.478 | Denali Data Feed | Disconnected from the server.
2025-05-26 11:55:11.478 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-05-26 11:55:11.478 | DTC Client socket (3) | Closed.
2025-05-26 11:55:14.484 | Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 443
2025-05-26 11:55:14.485 | DTC Client socket (3) | Creating socket.
2025-05-26 11:55:14.485 | DTC Client socket (3) | New receive buffer size: 0
2025-05-26 11:55:14.485 | DTC Client socket (3) | Connecting to IP: 69.39.70.246.
2025-05-26 11:55:17.958 | DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2025-05-26 11:55:17.959 | DTC Client socket (3) | CloseSocket call.
2025-05-26 11:55:17.959 | DTC Client socket (3) | Closed.
2025-05-26 11:55:17.959 | Denali Data Feed | Failed connections: 291
2025-05-26 11:55:17.959 | DTC Client socket (0) | CloseSocket call.
2025-05-26 11:55:17.959 | Denali Data Feed | Disconnected from the server.
2025-05-26 11:55:17.959 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-05-26 11:55:20.969 | Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048
2025-05-26 11:55:20.970 | DTC Client socket (3) | Creating socket.
2025-05-26 11:55:20.970 | DTC Client socket (3) | New receive buffer size: 0
2025-05-26 11:55:20.970 | DTC Client socket (3) | Connecting to IP: 69.39.70.246.
2025-05-26 11:55:22.125 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-05-26 11:55:22.139 | DTC Client socket (2) | CloseSocket call.
2025-05-26 11:55:22.139 | SC Data with Depth | Failed connections: 87
2025-05-26 11:55:22.139 | DTC Client socket (0) | CloseSocket call.
2025-05-26 11:55:22.139 | SC Data with Depth | Disconnected from the server.
2025-05-26 11:55:22.139 | DTC Client socket (2) | Closed.
2025-05-26 11:55:22.139 | SC Data with Depth | Data feed disconnected. Will reconnect in 0 seconds.
2025-05-26 11:55:22.141 | SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048
2025-05-26 11:55:22.141 | DTC Client socket (2) | Creating socket.
2025-05-26 11:55:22.142 | DTC Client socket (2) | New receive buffer size: 0
2025-05-26 11:55:22.142 | DTC Client socket (2) | Connecting to IP: 67.214.125.7.
2025-05-26 11:55:24.384 | DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2025-05-26 11:55:24.385 | DTC Client socket (3) | CloseSocket call.
2025-05-26 11:55:24.385 | Denali Data Feed | Failed connections: 292
2025-05-26 11:55:24.385 | DTC Client socket (3) | Closed.
2025-05-26 11:55:24.385 | DTC Client socket (0) | CloseSocket call.
2025-05-26 11:55:24.385 | Denali Data Feed | Disconnected from the server.
2025-05-26 11:55:24.385 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-05-26 11:55:27.421 | Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048
2025-05-26 11:55:27.430 | DTC Client socket (3) | Creating socket.
2025-05-26 11:55:27.431 | DTC Client socket (3) | New receive buffer size: 0
2025-05-26 11:55:27.431 | DTC Client socket (3) | Connecting to IP: 69.39.70.246.
2025-05-26 11:55:30.914 | DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2025-05-26 11:55:30.914 | DTC Client socket (3) | CloseSocket call.
2025-05-26 11:55:30.914 | Denali Data Feed | Failed connections: 293
2025-05-26 11:55:30.914 | DTC Client socket (3) | Closed.
2025-05-26 11:55:30.914 | DTC Client socket (0) | CloseSocket call.
2025-05-26 11:55:30.914 | Denali Data Feed | Disconnected from the server.
2025-05-26 11:55:30.914 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
[2025-05-27 06:35:01]
We apologize for the delay. We see what the problem is. Remove the ds13.sierracharts.com server from this setting:
Sierra Chart Server Settings: CME Exchange Data Feed Server Address and Port Override (Global Settings >> Sierra Chart Server Settings >> General >> Special)
That server is no longer available. You could use the New Zealand server instead which is listed in the documentation linked above.
We also want you to restart Sierra Chart if you are still having a problem.
Date Time Of Last Edit: 2025-05-27 06:35:09
[2025-05-27 06:55:44]
Thanks , It work now.
