Date/Time: Wed, 25 Nov 2026 21:36:03 +0000
How to get the visual label of studielines on right side of scale
View Count: 937
[2025-05-24 12:18:47]
User216891 - Posts: 6
Hi.
I have tried most of the options regarding right, left sides of chart. How do I manage to get the labels on the right side of the price scale like in the picture?
Best regards.
image1_1_2.jpg / V - Attached On 2025-05-24 12:17:57 UTC - Size: 7.17 KB - 359 views
[2025-05-27 15:18:38]
You need to setup the "Label" column in the DOM first. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
Then you can specify to display the Name/Value label in the Label column. Refer to the following (item #7 in particular):
Chart Studies: Subgraphs Tab >> Name and Value Labels
