Date/Time: Wed, 25 Nov 2026 21:36:05 +0000
volume
View Count: 752
[2025-05-23 12:53:35]
User914407 - Posts: 65
Comment afficher les volumes contenus dans les barres 30 minutes TPO du Market Profile ?
Merci
[2025-05-23 14:06:38]
From Google Translate:
How to display the volumes contained in the 30-minute TPO bars of the Market Profile?
There is not a way to do this from the TPO Profiles themselves. The best option is to have a separate chart that shows the volumes for 30 minute bars.
But, if you want to have this on the TPO chart, then the only way to do this would require that you have the "Letters/Blocks in Own Column" enabled for all the TPO Profiles. Then you can setup a separate 30 minute chart and add the Volume study to it. Then use the "Study/Price Overlay" to overlay the Volume study onto the TPO Profile chart. Refer to the following:
Study/Price Overlay Study
