Date/Time: Wed, 25 Nov 2026 21:46:05 +0000
Impossible to mark Trade Simulation Mode On
View Count: 807
| [2025-05-20 10:07:33] |
| User395078 - Posts: 1 |
Hello I am a new user, in trial mode, and i would like to trade in simulation mode. But, i can not check the Trade Simulation Mode On and i think this is the reason why i am not in simulation mode. See snapshot for a better understanding. |
Private File |
| [2025-05-20 11:54:51] |
| Sierra_Chart Engineering - Posts: 25483 |
In the case of when using the Trading Evaluator service this is the case because it is designed to be a server-based service to keep track of your trading. And we do not want users to accidentally enable Trade Simulation Mode preventing server-based logging. To solve this: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-20 11:55:09
