Date/Time: Wed, 25 Nov 2026 21:46:07 +0000
How do you limit the info displayed in Chart Tools Value window
View Count: 761
| [2025-05-18 15:47:35] |
| User763335 - Posts: 133 |
Hi pls have a look at the attached screenshot. I just want to display the Open,High,Low,Last values from Region 1 in the chart tool values window, when I click or hover over a particular bar, nothing else. How can I do that? Thanks Date Time Of Last Edit: 2025-05-18 15:48:45
Private File |
| [2025-05-18 16:54:21] |
| Sierra_Chart Engineering - Posts: 25483 |
This is explained here: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Also if that is all you want we would recommend, just using the compact tool values window: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools The Compact Tool Values Window will provide you what you need without having to do any custom configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-18 21:26:09
| [2025-05-19 14:59:53] |
Also refer to the following: Chart Settings: Chart Values Field Settings (Button) (Chart >> Chart Settings >> Display >> Chart Values menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
