Date/Time: Wed, 25 Nov 2026 21:46:08 +0000
Historic CME S&P Data
View Count: 577
| [2025-05-16 14:34:58] |
| User237068 - Posts: 1 |
I want to convert my trial a/c to a paid account. I require approximately 5 years of intraday data (5 mins) for only the S&P contract for back-testing. No real time access required. Can you please advise which package is required. Thanks |
| [2025-05-16 15:11:11] |
If you do not need real-time data and you are not going to be trading directly from Sierra Chart, then you can use one of the "Base" packages. Refer to the information at the following link: Description of Service Packages and Pricing: Base Packages As long as you are on a paid package (of any kind) you will have access to the historical data. We have more than 5 years of 1 tick data for the S&P 500 futures, so this will not be an issue. If you are not already familiar with the Continuous Futures Contract in order to view multiple contracts in a single chart, refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
