Date/Time: Wed, 25 Nov 2026 21:46:07 +0000
Alert Condition for Numbers Bars
View Count: 649
| [2025-05-16 00:29:50] |
| tendiemann - Posts: 16 |
Hello, Is it possible to create an alert condition based on values generated from the 'show historical pullback ask volume bid volume difference' data? Specifically when the chart settings - chart data - historical pullback data (list) is set to reset and accumulate on new or touch high/low? I want to generate an alert when the values that appear above a bar are both positive or both negative. I tried to do this in a spreadsheet study but the data does not appear as it is not a subgraph option of the numbers bar study. |
| Attachment Deleted. |
| [2025-05-16 14:32:51] |
We assume you are getting the pullback values from the Numbers Bars Calculated Values study. As such, refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
