Date/Time: Wed, 25 Nov 2026 21:46:08 +0000
Ask Volume/Bid Volume Difference (text) from Study to DOM Columns
View Count: 706
[2025-05-15 16:19:26]
countryboy92 - Posts: 120
Is there a way to add a column on my DOM for Delta (Ask Volume/Bid Volume Difference Study)? When I add it as a study on my DOM it displays more than 1 number at each price level.
[2025-05-15 16:52:27]
this was asked on this thread; how do I add Delta in a column to the left of the price? I am not a programmer
Issue adding delta to my DOM
[2025-05-15 17:13:15]
There is not a built-in method to display the Delta as a column in the DOM. The best you can do with the built-in tools is to use the Volume by Price study setup to be to the left of the DOM to display these values.
We do not understand what you mean by "When I add it as a study on my DOM it displays more than 1 number at each price level." What study are you referring to?
You can do this programmatically using the General Purpose columns. Refer to the following:
ACSIL Programming Concepts: Custom Free Form Drawing into Chart Window
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2025-05-15 22:44:46]
I can't really program anything. Is there a way to copy the study here "numbers bar calculated values" that has "Delta" subparagraph to my DOM chart?
attachmentFootprint with Delta.Cht - Attached On 2025-05-15 22:43:54 UTC - Size: 6.47 KB - 331 views
[2025-05-16 14:27:45]
No, you can not copy the Numbers Bars Calculated Values to a Trading DOM.
The solution you want is to use the Volume by Price study as we mentioned above.
