Date/Time: Wed, 25 Nov 2026 21:45:59 +0000
historical data on Friday
View Count: 1023
| [2025-05-13 07:37:25] |
| User981449 - Posts: 52 |
Hi, I've noticed that every Monday morning a portion of the previous Friday's historical data is missing. I don't trade on Fridays, and so far, the only way I've found to fix this is to delete all historical data and re-download it to retrieve Friday's data correctly. Is there an alternative workaround I can use to resolve this issue? Thank you in advance. |
| [2025-05-13 09:26:14] |
| Sierra_Chart Engineering - Posts: 25483 |
This does not make sense. Existing data cannot become missing unless it is getting filtered out from the chart for some reason. Provide an image of the chart, on Friday and again on Monday showing the missing data. Thinking about this we think we know what the problem is. Increase the Days to Load in the chart: Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-15 08:33:44] |
in the attached screenshot you can see the issue I'm experiencing every Monday morning. Friday Data are always truncated and the only fix is to delete and redownload all the historical data.
| [2025-05-15 14:24:23] |
As we are understanding this, what is occurring is that you are not connecting at all on Friday, so you are not getting the data in real-time at that time. Then when you start on Monday again, the data is not automatically downloading for Friday. Please confirm that what we state above is correct. We would need to see your Message Log from a Monday when you first connect and see if there is anything in it regarding downloading the missing data. Please get us the log next Monday after you connect and the charts are loaded and the data from Friday is not there. Follow these instructions to get us the log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-19 08:02:10] |
hi, as every Monday Morning I have the same issue. I've used SC until Friday 11:30 (NY time). Logs have been sent for analysis.
| [2025-05-19 15:32:36] |
If you have not already downloaded the missing data, can you please get us an image of a chart showing the missing data? Also, please let us know what your Global Time Zone is set to and what the Chart Time Zone is set to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-20 07:44:35] |
this is the chart showing the missing data and the chart Time zone
Private File Attachment Deleted. Private File |
| [2025-05-20 13:35:09] |
Follow the instructions here to download the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Also, in this screen image of the Chart Settings, Apply the session times: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=120890 Since some of them are not applied. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-20 13:35:33
| [2025-05-21 09:08:48] |
thank you
