Date/Time: Wed, 25 Nov 2026 21:45:57 +0000
Wifi requirements to run Sierra chart
View Count: 978
[2025-05-12 19:52:29]
rikki - Posts: 7
I have got this values from a wifi speed test
Download speed: 10.53Mbps
Upload 7.43 Mbps
Latency 37 Ms
I was wondering if it's enough to run sierra chart smoothly. Thanks
[2025-05-13 09:19:22]
One question is how are you determining the speed? You would want to run a speed test, to either Illinois or Michigan in the US.
And what exchanges do you want to receive data for?
In general that speed is sufficient. Sierra Chart certainly will always run smoothly. The question is whether there is enough bandwidth for market data at those speeds.
We recommend using high compression:
Sierra Chart Server Settings: Use Real-Time Data Compression (Global Settings >> Sierra Chart Server Settings >> General >> General)
And setting this to 250 ms or higher:
Sierra Chart Server Settings: Remote Buffer Delay Send Time In Milliseconds (Global Settings >> Sierra Chart Server Settings >> General >> General)
Date Time Of Last Edit: 2025-05-13 09:21:20
