Date/Time: Mon, 29 Apr 2024 11:09:39 +0000
Resize Price-Axis with Log-Scale
View Count: 2441
[2013-03-24 08:15:10] |
RH_05 - Posts: 2 |
Hi, when the price scale is linear, I can resize it with the mouse (left-click and draw). But that is not possible when the scale is set to logarithmic. How can I do that? Scale range is set to automatic. Of course I could set it to constant range but this messes up my chart when I change the symbol. And how can I define keyboard shortcuts for resizing and moving the price axis up and down? Thanks. Date Time Of Last Edit: 2013-03-24 08:18:01
[2013-03-25 14:52:25] |
1. There are mathematical problems when trying to compress and expand a Logarithmic scale. Although this depends upon the range of displayed prices. So we disable it in this case. You can use though Interactive Range Move instead though: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling Keyboard shortcuts are not supported for Moving the chart up and down. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
