Date/Time: Thu, 26 Nov 2026 03:42:07 +0000
Post From: Wildly incorrect PnL
[2026-03-09 14:08:41]
The way to correct this is explained at the following link:
Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss
If you have gone through the above and are still having a problem, then the date and time that you have entered for the chart loading of order fills must be set to a bad time. You need to set this to where you are flat in the market and from where the order fills are correct going forward. The easiest solution is to be flat in the market and then enter the current date and time.
