Date/Time: Sat, 18 May 2024 14:09:32 +0000
how to replace the value “point” in “tick” on the
View Count: 55
[2024-05-01 16:45:10] |
User819109 - Posts: 7 |
Hello, I can't find the solution to replace the value displayed on the trade window I use the symbol ES CME I'd like to replace the position values with ticks instead of points. 1 point = 4 tick I can't find the solution by modifying the data in the trade window. which setting should I go to? Thank you for your help. |
[2024-05-01 18:49:23] |
Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
