Date/Time: Sat, 18 May 2024 08:43:44 +0000
ZN chart issue
View Count: 55
[2024-05-01 14:12:58] |
ted chuang - Posts: 13 |
Hi, The ZN chart seems to be locked up for no reason? It cannot be moved left or right at all(Candle spacing works with the left mouse button pressed along the candle time in the bottom of the chart). As of this morning, I can see the price moving up n down in the DOM without any problems. However, the candles are just not shown at all. After unchecking Chart>Lock fill space, it still won't work. It's already 5/1 today yet the ZN still shows 4/30's chart. Please help fix the issue. Thank you |
ZN 050124.png / V - Attached On 2024-05-01 14:12:07 UTC - Size: 1.52 MB - 18 views |
[2024-05-01 14:43:12] |
Sierra_Chart Engineering - Posts: 14423 |
Select Chart >> Goto End of Chart. And we recommend enabling scrollbars on the charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-01 14:43:21
