Date/Time: Sat, 18 May 2024 12:40:44 +0000
Can't scroll the chart left or right
View Count: 47
[2024-05-01 13:25:50] |
ted chuang - Posts: 13 |
Hi, I can't scroll the chart to the right in order to see yesterday's candle history on the left side of it. The only thing I can do is to shrink the candles in the bottom of the time display of each candle. There's no issue to move the chart up n down. I did try the Chart>Lock Fill Space but it didn't work at all. This issue just appeared all of a sudden for not reason?! Thanks. |
[2024-05-01 14:40:17] |
Sierra_Chart Engineering - Posts: 14423 |
Is the scrollbar at the bottom of the chart disabled? You may need to load more data in the chart. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
