Date/Time: Sat, 18 May 2024 09:27:43 +0000
Current version 2634 possible crosshair bug
View Count: 63
[2024-05-01 13:24:48] |
User736551 - Posts: 7 |
Hello, I just installed the current version 2634 and I think there's a bug about "Crosshair" 'cause the x label and the y label are totally black (as you can see in the screenshot attached) so I can't see price and time (instead in the previous version 2568 I could, as you can see in the screenshot attached). Is it possible to solve it? Thanks for your attention and availability. Best regards. Mirko Cipriano |
[2024-05-01 14:38:52] |
Sierra_Chart Engineering - Posts: 14423 |
You need to adjust the Chart Values: Color Settings for this: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
