Date/Time: Sat, 18 May 2024 09:05:02 +0000
Quoteboard
View Count: 64
[2024-04-30 22:20:23] |
User915558 - Posts: 1 |
Hi, is it possible to have a quoteboard or a spreadsheet in Sierra chart that is showing relative volume and relative range as a percentage for a list of symbols ? Eg. ES- RVOL-150% -RRANGE-80% Thank you . |
[2024-05-01 14:05:04] |
The list of fields that are available with the Quote Board are listed here: Getting Quotes: Field Descriptions Refer to the following for how to change/add/remove fields for a Quote Board: Getting Quotes: Setting Fields to Display The items you reference (Relative Volume and Relative Range) are not available with the Quote Board. You can setup studies for these for individual symbols and then use the "Study Summary" window to view the information in a compact format. Refer to the following: Study Summary Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
