Date/Time: Sat, 18 May 2024 09:54:30 +0000
How To Print Last Candle Away from The Chart Price Border And Add a Line Before The Candle
View Count: 57
[2024-04-30 19:21:54] |
FelixAndres090519 - Posts: 1 |
How can I set my current candle to print further from the chart price border, and add a line from that border to the edge of the candle (not through the candle)? I can move the chart away from the border, but as soon as the next candle is printing it goes back to the border. Currently, my numbers candles (with individual delta profiles) are printing behind my right-aligned VBP, and it's a mess. I'm also using the CPL study, but I can only see a price line through the first candle and beyond, not before. Thanks |
[2024-04-30 19:45:10] |
To have the candles offset from the right-hand border, you need to use the "Lock Fill Space" option. Refer to the following: Chart Menu: Lock Fill Space (Chart menu) If you are referring to the Current Price Line and you want it in that locked area to the right only, then set the following Inputs: - Display Current Price Line on Chart Bars: No - Forward Project Current Price Line: Yes - Number of Forward Projection Bars: 100 (or 1000 if 100 is not enough - you just want something large enough to cover the locked fill space) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
