Date/Time: Sat, 18 May 2024 10:07:52 +0000
What is this histogram on the right of the chart?
View Count: 107
[2024-04-30 16:46:01] |
User552238 - Posts: 2 |
I saw this one and wondered what it is and how to set it up. It's like an order book that could be attached to the right of the chart.
Screenshot 2024-04-30 104145.png / V - Attached On 2024-04-30 16:45:35 UTC - Size: 65.51 KB - 37 views |
[2024-04-30 17:20:33] |
Refer to the following: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-30 22:53:48] |
Thanks, That's what I am looking for. However, I only have one bar level on the DOM for some reason. Could you tell me why? I am using the data from finance for ETH-USDC |
Screenshot 2024-04-25 111743.png / V - Attached On 2024-04-30 22:53:24 UTC - Size: 12.84 KB - 18 views |
[2024-05-01 09:28:32] |
Sierra_Chart Engineering - Posts: 14423 |
There is no market depth data available for Binance symbols if that is what the chart is for.
