Date/Time: Sat, 18 May 2024 18:03:14 +0000
Unable to see charts
View Count: 150
[2024-04-27 23:17:08] |
UserSJ - Posts: 3 |
Hi first time using Sierra Downloaded software from your website 64 bit. Downloaded on my laptop. Created account All I tried to do was access chart for natural gas and the screen was black On the message log kept saying unable to load data Can't see any charts Tried nq chart as well didn't work Is there a number I can call Date Time Of Last Edit: 2024-04-27 23:32:49
[2024-04-28 00:33:55] |
User584084 - Posts: 241 |
1) Go to the SC Menu (Upper Left Corner) and select: File >> Find Symbol. 2) Click the + next to Futures - Nymex. 3) Click the + next to NG for Nat Gas. 4) Highlight the NG June 2024 contract with the mouse. 5) Click the gray 'Open Intraday Chart' button below and then Close the Find Symbol Window. 6) Right click on the chart and select 'Studies' to add studies. 7) Go to the SC Menu (Upper Left Corner) and select: Chart >> Graph Draw Types to select different types of Candlesticks. SC Tutorial Link Below: https://www.youtube.com/watch?v=Gldk81rWZ5U Date Time Of Last Edit: 2024-04-28 01:17:56
[2024-04-28 03:49:12] |
User112927 - Posts: 6 |
OP are you on trial period?
[2024-04-28 14:40:16] |
Sierra_Chart Engineering - Posts: 14423 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. To get started with Sierra Chart, follow the Sierra Chart setup instructions here: Sierra Chart Setup Instructions 1 After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-01 17:47:29] |
UserSJ - Posts: 3 |
How do i see footprint charts - showing bid ask order per candlestick where i can see cumulative delta as well as how to make sure im in the real enviroment nat gas is showing delayed movement |
[2024-05-01 17:48:57] |
UserSJ - Posts: 3 |
open intraday chart only showing 1 min how to see the rest of time frame
