Date/Time: Thu, 02 May 2024 22:50:32 +0000
ILQ (Velocity) Futures to Advantage Futures Data Feed Change
View Count: 2280
[2014-04-02 22:43:37] |
Sawtooth - Posts: 3992 |
TradePro Futures has a TT FIX feed. They also clear through ILQ.
[2014-04-03 05:13:37] |
You will need to change the symbol of the charts following the instructions here when you switch to a new Data or Trading service: https://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html And fresh data will be downloaded for the new symbols. For the time being we recommend that you use CTS through Advantage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-03 05:14:10
[2014-04-07 02:21:40] |
TT FIX to CTS T4 will involve renaming files and possibly adjustment of the price values through Edit >> Adjust Data: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
