Date/Time: Sun, 05 May 2024 11:55:23 +0000
[User Discussion] - Graphics performance issue on Linux/Wine
View Count: 7065
[2020-10-01 07:26:29] |
ganz - Posts: 1048 |
some info in terms of performance on wine SC 2168 Fedora 32 + RPMFusion kernel v. 5.8 nv blob v. 450 Hybrid Graphics on Zen Aio 4k Intel HD: - 2d performance is quite well on Wayland/XWayland and it's +10% down to X11 - OpenGL SC option is decreased CPU usage for 50-60% then Nvidia blob was added and X11 was set back: with OpenGL option all graphs on charts are missing so no visible objects were presented: __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia wine ./SierraChart_64.exe with no OpenGL option all graphs and performance still the same as on Intel HD /X11 was so Intel/XWayland is the solution in case of Hybrid Graphics will be used https://rpmfusion.org/Howto/Optimus?highlight=%28CategoryHowto%29 |
[2020-10-01 08:55:20] |
with OpenGL option all graphs on charts are missing so no visible objects were presented: __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia wine ./SierraChart_64.exe I've tested it on Ubuntu 18.04.5 with the same blob ver using Prime scripting set 2d performance is worse or the same than Intel HD/Wayland/Xwayland was ( using OpenGL SC option ) and it was just awful with no OpenGL SC option at all Date Time Of Last Edit: 2020-10-01 08:56:49
[2020-10-02 11:18:50] |
Ubuntu 20.04 / Cinnamon 20 and Windows 10 were tested as well so my list of 2d performance results: 1st place is for IntelHD/Wayland/XWayland ( super efficient but it shouldn't be ) 2nd place is for IntelHD/X11 -10% to 1st 3rd place is for Nvidia/X11 -15% to 1st 4th place is for Nvidia/Wayland/Xwayland -25% to 1st 5th plase is for Nvidia/Windows -50% to 1st ( O_O ... wtf ? ) Gnome w themes and dash2panel extension looks the best for everyone. Date Time Of Last Edit: 2020-10-02 18:03:29
[2020-10-15 03:55:44] |
a number of setups has been tested and it is clear now it is really worth to prefer amd gpu hw to nvidia hw in order to get well 2D performance on Linux and no need to be on the cutting edge here to be OK https://help.ubuntu.com/community/RadeonDriver https://help.ubuntu.com/community/AMDGPU-Driver |
[2020-10-17 02:44:33] |
a lot of people just hate gnome 3 so amd hdXXXX hw works just cool using marco+compton on linux mint/mate 20 |
[2020-10-26 11:57:06] |
the best combo at this moment is AMD hw and CentOS 8 ~50% adv 2d graph perf to any tested Linux distro https://www.centos.org/ https://fedoraproject.org/wiki/EPEL https://rpmfusion.org/Configuration https://computingforgeeks.com/how-to-install-latest-kernel-on-centos-linux/ https://www.gnome-look.org/browse/cat/135/ord/rating/ https://www.gnome-look.org/browse/cat/134/ord/rating/ https://extensions.gnome.org/extension/1160/dash-to-panel/ https://extensions.gnome.org/extension/945/cpu-power-manager/ |
