Date/Time: Fri, 10 May 2024 16:09:05 +0000
[User Discussion] - Python for Sierra Chart
View Count: 34946
[2014-07-10 03:45:46] |
Kiwi - Posts: 375 |
OK. I had read that and didn't see why HDF5 was chosen. Python is extremely happy reading CSVs (or even SCIDs with a little conversion). |
[2014-07-10 08:09:53] |
ganz - Posts: 1048 |
Kiwi The CSV is good but we need to ask SC Team to support ISO 8601. http://pandas.pydata.org/pandas-docs/version/0.13.1/io.html#io-read-csv-table read_csv has a fast_path for parsing datetime strings in iso8601 format, e.g “2000-01-01T00:01:02+00:00” and similar variations. If you can arrange for your data to store datetimes in this format, load times will be significantly faster, ~20x has been observed. And yes, I'm happy to use scid for charting any data I need. Another "+" for HDF5 : the format has an internal "file system". It makes much more easy to manage thousands of symbols, it makes users feel comfortable with a db, I believe. |
[2014-07-10 13:14:28] |
for the record: in order to use the script on a x64 system it needs to define the byte order for the struct function as explained there https://docs.python.org/3.0/library/struct.html for little-endian in other words use '='or '<': src = struct.unpack('=d4f4L', tick)
or src = struct.unpack('<d4f4L', tick)
[2014-07-12 05:34:31] |
Kiwi Why use HDF5?
http://pytables.github.io/FAQ.html#why-hdf5 Why HDF5? HDF5 is the underlying C library and file format that enables PyTables to efficiently deal with the data. It has been chosen for the following reasons: Designed to efficiently manage very large datasets. Lets you organize datasets hierarchically. Very flexible and well tested in scientific environments. Good maintenance and improvement rate. Technical excellence (R&D 100 Award). It’s Open Source software |
[2014-08-14 22:05:43] |
User13778 - Posts: 24 |
Excellent work Kiwi I use Python to analyse NQ and ES and trade with Interactive Brokers. Im looking to do similar with a python / Sierra Chart system on FXCM |
[2014-10-30 14:09:26] |
User85468 - Posts: 9 |
Hello, how can I have my PnF chart (or reversal bar chart), say in 15 minute periods, print and/or remove Xs or Os depending on the direction, for every price move on the last bar? It works on the Tick, but the chart is really worthless in such a short time-frame. Kind regards |
[2014-11-22 23:30:23] |
Why use HDF5?
http://youtu.be/hnhN2_TpY8g |
[2015-04-01 14:27:50] |
Shaharabin - Posts: 28 |
Hi Guys, Interesting stuff. My question to you all is; can i export real time "Time and Sales" data from sierra chart and use it with any other program? using any type of language. My end goal is to stream that data onto the PC's serial port and build a physical gauge Thank for any replay Shahar. |
[2015-04-01 18:46:10] |
In regards to post #32 something that may be of help for this, is the relay server: https://www.sierrachart.com/index.php?page=doc/doc_RelayServer.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-01 20:03:51] |
Holy-S*** This is great stuff, how did I not know about it.... I'll start working on it, which means, a whole lot of new questions coming your way :) Thanks a lot! |
[2015-04-01 22:22:56] |
If you have further questions for Sierra Chart support, post them in a new thread because we are not monitoring this thread. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-17 20:26:58] |
rhovega - Posts: 279 |
Hi @ganz hoping you are still around this forum and get to see this! I am new to Python; running your code from post 22 gives me error "IndexError: list index out of range", while running code "~/>python3 this_script.py chart.scid" (with the appropriate filenames) from the Python console gives me error "SyntaxError: invalid syntax". Can't figure it out. I am aware this is a very old thread but maybe if still around you could give me some pointers to move along. Would be much appreciated. Thank you. |
[2017-07-22 09:10:57] |
rhovega hey ... the only way in this case is to learn what each of line exactly does study Python step by step in order to get it working imo :) |
[2019-03-05 19:33:57] |
Chad - Posts: 231 |
@Kiwi, have you looked into adding a function within your Python script for reading market depth (.depth) files?
[2019-03-05 22:45:49] |
Kiwi - Posts: 375 |
No CB, I trade purely on price vs time My latest work on Python has been a program using ib_insync to connect to the twsapi directly but its for basic information presentation & order entry/management to complement TWS charting. https://i.imgur.com/nRbivpe.png |
[2019-05-10 01:25:52] |
Kiwi - Posts: 375 |
So here's another little bit of code. It will convert all the text files in a directory into scid files in another directory. If the constant KEEP_UPDATING was True it will then check the text files every REFRESH seconds and if they've changed it will update the scid files. Set FILES_IN and FILES_OUT. In windows the format is "C:\\mydir\\mysubdir\\" Also set Timezone if you wish to change the times in Sierra's scid files (Sierra saves them in the UTC time zone). Save the code in a file named something like Text2Scid.py and run it using python Text2SCid.py. Tested with Python 3.7.Have fun: """
Convert's Text files to SCID files for SierraChart It will create a new scid file for every text file it finds format is assumed to be D T O H L C V T with comma separated variables It will continue to update the scid file every REFRESH seconds generally refresh would be set to 1/2 the time period for the text file updates """ import os import struct from time import sleep from datetime import datetime as dt, timedelta as tdelta import subprocess # these are linux format, windows might need to use double backslashes \\ FILES_IN = "/home/john/Python/Trading/textfiles/" FILES_OUT = "/home/john/zRamdisk/SierraData/" TIMEZONE = 0 # scid saved as UTC, use this if the text file is another time zone KEEP_UPDATING = True # set to False to convert and stop; True for live updating REFRESH = 0.25 # refresh every 1/4 second for 1/2 second updating text files TEXT_FILE_SUFFIX = ".txt" # usually .txt or .csv sizeHeader = 0x38 sizeRecord = 0x28 file_header = (b'SCID8\x00\x00\x00\x28\x00\x00\x00\x01\x00\x00\x00\x00\x00' + b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' + b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' + b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00') def excel_date(datetime, offset=TIMEZONE): """convert date&time with offset in hours to excel format for scid""" delta = datetime - dt(1899, 12, 30) + tdelta(hours=offset) return delta.days + delta.seconds / 86400 def python_date(exceldt, offset=TIMEZONE): """convert date&time with offset in hours to python format""" excel_as_delta = tdelta(days=exceldt//1) + tdelta(seconds=exceldt%1*86400) return dt(1899, 12, 30) + excel_as_delta + tdelta(hours=offset) def write_struct(record, f): if len(record) == 8 and record[0][0].isnumeric(): out = [excel_date(dt.strptime(f'{record[0]} {record[1]}', '%Y-%m-%d %H:%M:%S.%f'))] out.extend([float(s) for s in record[2:]]) # note that SC packs dt, O, H, L, C, T, V not V, T so swap them wt = struct.pack('d4f4I', out[0], out[1], out[2], out[3], out[4], int(out[6]), int(out[5]), 0, 0) f.write(wt) def create_base(f): record = None with open(FILES_OUT + f[: -3] +'scid', "wb") as scidfile: scidfile.write(file_header) with open(FILES_IN + f, "r") as txtfile: for line in txtfile: record = line.split(',') write_struct(record, scidfile) return f'{record[0]} {record[1]}' # will update when date+time changes def update_if_changed(files): for f in files: with open(FILES_IN + f, "r") as txtfile: record = txtfile.readlines()[-1].split(',') last_dt = f'{record[0]} {record[1]}' if files[f] == last_dt: continue files[f] = last_dt with open(FILES_OUT + f[: -3] +'scid', "ab") as scidfile: write_struct(record, scidfile) if __name__ == '__main__': files = sorted(k for k in os.listdir(path=FILES_IN) if k[-4:] == TEXT_FILE_SUFFIX) files = {k: '' for k in files} for f in files: files[f] = create_base(f) print('finished base') if KEEP_UPDATING: # now test each input file each REFRESH interval & update if datetime changed while True: sleep(REFRESH) update_if_changed(files) edit: changed so that it will run despite the extra space & linefeed added after each line. Probably better to use the attached file though. Date Time Of Last Edit: 2019-05-11 12:42:07
Text2Scid.py - Attached On 2019-05-11 12:41:30 UTC - Size: 3.31 KB - 563 views |
[2019-05-10 06:02:42] |
User21223 - Posts: 90 |
Hi Can anyone check the above code. Because I'm getting an error. I do not know if it's my part. C:\Users\mkruss>python Text2Scid.py File "Text2Scid.py", line 33 file_header = b'SCID8\x00\x00\x00\x28\x00\x00\x00\x01\x00\x00\x00\x00\x00\x0 0' \ ^ SyntaxError: unexpected character after line continuation character Sample text file to be converted into a scid in the attachment Date Time Of Last Edit: 2019-05-10 06:12:59
Attachment Deleted. Symbol2.txt - Attached On 2019-05-10 06:11:49 UTC - Size: 18.34 KB - 524 views |
[2019-05-10 06:40:08] |
Kiwi - Posts: 375 |
Yes. It seems this board adds extra characters (an extra space and a linefeed) at the end of the line when you cut & paste from it. So here's a raw version without extra characters.
Date Time Of Last Edit: 2019-05-10 06:46:10
Text2Scid.py - Attached On 2019-05-10 06:39:58 UTC - Size: 3.58 KB - 569 views |
[2019-05-10 08:31:55] |
Now. This error is shown C:\Users\mkruss>python Text2Scid.py finished base Traceback (most recent call last): File "Text2Scid.py", line 84, in <module> update_if_changed(files) File "Text2Scid.py", line 60, in update_if_changed record = subprocess.check_output(['tail', '-1', FILES_IN + f]).decode().spli t(',') File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 395, in check_output **kwargs).stdout File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 472, in run with Popen(*popenargs, **kwargs) as process: File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 775, in __init__ restore_signals, start_new_session) File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 1178, in _execute_chi ld startupinfo) FileNotFoundError: [WinError 2] Nie można odnaleźć określonego pliku C:\Users\mkruss> I will add that the scid files were created in the Siarrachart directory. You can load them by Open Intraday Chart But they do not freshen up automatically |
[2019-05-10 08:37:59] |
Kiwi - Posts: 375 |
Make sure your file paths have no spaces in them. For example SierraChart or Sierra_Chart, not Sierra Chart. Some python modules have problems with them so it's easier not to include spaces in paths.
Date Time Of Last Edit: 2019-05-10 08:43:08
[2019-05-10 08:59:25] |
I had Sierra Chart. I changed to SierraChart. but the problem still occurs. Same error |
[2019-05-10 09:35:47] |
Kiwi - Posts: 375 |
After the line if name == main add this and post the result: import sys; print(sys.version)
I'll do another version tomorrow that's more defensive to see if the problem is detectable. |
[2019-05-10 09:51:56] |
Microsoft Windows [Wersja 6.1.7601] Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone. C:\Users\mkruss>python Text2Scid.py 3.7.3 (default, Mar 27 2019, 17:13:21) [MSC v.1915 64 bit (AMD64)] finished base Traceback (most recent call last): File "Text2Scid.py", line 85, in <module> update_if_changed(files) File "Text2Scid.py", line 60, in update_if_changed record = subprocess.check_output(['tail', '-1', FILES_IN + f]).decode().spli t(',') File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 395, in check_output **kwargs).stdout File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 472, in run with Popen(*popenargs, **kwargs) as process: File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 775, in __init__ restore_signals, start_new_session) File "C:\Users\mkruss\Anaconda3\lib\subprocess.py", line 1178, in _execute_chi ld startupinfo) FileNotFoundError: [WinError 2] Nie można odnaleźć określonego pliku |
[2019-05-10 12:55:35] |
Kiwi - Posts: 375 |
I'll do a new version tomorrow but you should be able to get it done by replacing record = subprocess.check_output(['tail', '-1', FILES_IN + f]).decode().split(',') with: record = txtfile.readlines()[-1].split(',') edit: corrected version of the file on Post #41 Date Time Of Last Edit: 2019-05-11 23:47:48
