Date/Time: Mon, 20 May 2024 15:58:10 +0000
[Locked] - ZigZag & Swing Hi/Lo: SERIOUS ISSUE
View Count: 3767
[2014-12-20 21:54:48] |
We identified the problem when using the Swing High and Low study with New Spreadsheets and this is resolved. I noticed that the study value can changed at previous bar and not updated in real time at current\last bar http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s242 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-22 11:09:05] |
User90848 - Posts: 57 |
Thank you for respond. when I Overlay a studies with Study/Price Overlay to another chart the studies are not automatically updated and redraw? from what i remember there was a similar issue with this study before and you solved in version 1209. |
[2014-12-22 17:47:16] |
In response to post #26, this is unrelated to this thread. Start a new thread and attach a Chartbook which contains 2 charts demonstrating the problem. Do not include any studies which are not relevant to the issue. Each chart should only contain one study. This thread is now locked and closed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
